I would agree with you, I own a 282, but a 272 is also a fine preamp/streamer, so the point is to enjoy music without thinking too much about it. You got there, enjoy the system and don’t let anyone tell you otherwise.
to bring out more resolution, one needs to spend more on cables from Naim or Chord… Not sure that I would disturb system balance if the system is playing well and sounds musical.
personally I think reading all the comments about the various combinations the two things I would want to look for is source first and balance in what ever combination that comes
over the years I have always gone source first, then a focus on Pre and then the rest of the system
for me using at 10K source (with out PSU) with out a matched pre and then the rest of the system does not make sense - is a 272/555/300 balance - YES and then following that is ND555/555/272/300 balanced on a source basis, I would have to say NO IMO
if @AhTiong you going for ND555/555/252/SC/300 - you are going to have one superb music system, and that would be my end goal, and to be perfectly honest even 282/HCDR would give you a better balance, and having used that combo with 300 I know it is very well matched
I didn’t know (no, I never go and read the personal data of the poster so I ignore what system he owns - Ah Tiong, this is not for you) that you have a 300DR. This, in my opinion, changes the thing a bit. I have heard a full 500 system many times: a guy I know has one. He uses it with Ovator S-600s. I also have a brother-in-law who has moved from a SN to a 252/300 (non DR). He has Harbeth SHL5s. So far, the 300 - which I also know well because a dealer friend of mine has it in stock permanently - is the most pleasing and complete Naim amp I have heard. Why do I say so? Because if I had one I would not sell it for a 500. Taste is taste, it may be a completely different story for you, but I don’t think the change is worth the cost. The 300 is a wonderful amp, has the best, deepest, more controlled and musical bass I have heard in any Naim amp, is mannered but is Naim, and the 252 - once you get accustomed to its mildly soft presentation, has the best musical flow I have heard in any Naim preamp. A pre/power combo like that is not sold, in my simple and perhaps immaterial view; but adding a super source might have a sense.
What’s a super source, though? My brother-in-law has three sources: a CDS3/XPS, an HDX, a Squeezebox Touch for Tidal. We occasionally spend long evenings listening, evaluating, exchanging opinions. Every once in a while we agree completely on something.
Something I’ve heard is that the HDX is still a magnificent machine, that it still holds its own vs the CDS3, that its Internet Radio is better than almost any other devices’ I’ve heard, that the same piece of music played on CD on the CDS3, as file from the HDX and from Tidal on the SBT, seemed to be a hint more enjoyable from the SBT’s Tidal. Something I’d never have bet a penny on until I heard it.
So, while I understand the idea of having a full 500 system shining in the living room, please do some tests, erase pre-conceptions and remember that money doesn’t grow on trees.
I assume the 272 is in place already.
The 272 with a 555ps seems to satisfy a lot of people, the bare 272 not so much. An ND555 with two ps also has its fans, I’m not one of them based on what I heard in a Naim run demo, but the room was evenly split between preferring one or two ps.
If after trying it, two ps does seem to have merit to you this opens up the possibility to run both the ND555 and 272 from 555ps as a first step, at a bit of a premium admittedly, and when a 552 arrives transferring the second ps to the ND.
I see now that you’re already considering a 252. Good. On the other hand - and please take it as a mere observation, totally non-judgmental - if you can be in doubt about buying a 555PS or not like I would be about, say, a new jacket, it means that perhaps - your good luck and merit - money is not an issue for you. If such is the case, I think that the decision should even more be made on sonic grounds exclusively.
Sounds like you can comfortably get to the system suggested by @Antz
ND555/555PS/252/SC/300
and I completely agree this would be a fantastic system.
Only suggestion would be to look for pre-owned 552 as it’s not a lot more than a 252/SC, particularly in the long term if you are aiming at a full 500 set up.
Agreed I have seen two recently serviced older DR examples go for just under £10,000 on a well known auction site.
A non DR but serviced NAP500 went with a buy it now for £6000 the other week also.
For £20,000 you’d rather hope to hear a decent improvement. If you do get the 555 and are thinking of buying the 252 and Supercap new, then do try to stretch for a used 552. People may say that it’s not much better than a 252 but I disagree. It’s massively better and puts you in touch with the music in a way that the 252 simply cannot.
@AhTiong@anon4489532. I’ve got the option on a used 252 at the moment and it would no doubt provide a more mature sound with greater resolution e.g. better! But I know I’d only hanker for a 552 so I’m going to leave well alone!
