just switched streamer on to play a few tunes and there’s no output from right speaker swapped interconnects and inputs etc to no avail any ideas anyone ?
unit is 6mths old
Have you swopped Din to RCA outputs? What about your amp? Have you swopped speaker cables to rule that out?
Broken relay, contact your dealer to organise a repair.
Does anyone know if these relays are swapped out like-for- like at Salisbury, or do they fit a revised/more relaible version ?
They fit the same type of relay like for like, but presumably from a different batch.
Thanks for replies
I take it this relay is a known problem well its of to the dealers thursday a.m
cheers again
A quick footnote
as hollow had suggested tried rca output both channels so faulty din relay as suggested
thanks again
