Nd5xs2 rc?
Is this guy capable of remote control? I several times got it muted when I was changing the volume on my 404 amp using the RC. Not exactly muted - it just lost the source.
There’s no IR remote control on the ND5XS2, just a 3.5mm IR socket, so there should be no chance for another IR remote to interfere here unless you have connected into this socket.
When you say the amp “lost the source” do you mean it change input or just cut out? I don’t know the “404” amp but I would probably look here first.
I meant that the streamer suddenty lost its source. When I opened the app I’ve found that none was chosen. The only action from my side were with the RC for 404.
