Nd5xs2 with wifi bridge
Here are some observations I’ve made and maybe somebody finds them useful.
I’ve added a wifi bridge (Tp-link archer mr200) to add a 5ghz coverage. Everything at home works fine except for the streamer. The streamer from time to time refuses to function with the application when they are on different wifi networks.
Say, the application displays as if the streamer is playing, the song progress is incrementing, but at the same time, the streamer remains dead silent and even the green logo is dim. I have to manually turn on the streamer, and after that it operates as expected.
Another issue - the streamer sometimes continyes to be turned on, when usually it goes into sleep after half an hour.
When I moved it to 5ghz network all such issues gone.
