Good evening, everyone. I would appreciate your valuable advice. Here is the situation: I have an nDAC that is about 15 years old and has always been used with an XPS2. Do you think it is worth having the DAC recapped? Thanks in advance.
don’t see why it would need it at all or certainly not on the normal frequency.
It’s a low voltage device so I doubt if the caps get hot or stressed. If anything I’d probably say instead of the normal 12-15yrs it could be 20+ for the nDAC.
FWIW I don’t think the Naim DAC has a specific service schedule or regime. Has performance suffered in some way or are you experiencing issues with it?
If the XPS2 is the same age then that may well be more deserving of a service as AFAIK that does have a service schedule of around 12-15 years.
Yes, actually, the XPS2 was recapped four years ago.
My nDAC is 16yrs old and the XPS2 was serviced in 2021 so similar to you.
I have no intentions of getting the nDAC serviced.
There’s a whole other thread on nDAC servicing if you search.
Maybe more than one!
I have been in comms with Naim support in the last few weeks and this was one of my questions.
The response was if it ain’t broke it don’t need a service.
They obviously did advise servicing any external PSUs powering the DAC of course.
I just had my nDac recapped here in NZ. I was a nice uplift in sound, unmistakable really. More air, space and detail. As someone else here put it, a little less ‘dark’.
Servicing is there to prevent failure, deal with degradation, and restore to design. What Naim means by not suggesting an internal service, I can only guess. Are they saying to wait until it fails? Are there no items that degrade? I guess that what could be replaced versus the cost they charge would not be seen by many as good value for money. There are a number of electrolytics in the power supply and tants that are typically changed in other Naim items, so why not in the DAC?
For items like power amps and power supplies there are set service regimes, mainly because these use big caps that will require replacement after a period of time and preventative service is always a good idea with a power amp to prevent any possible speaker damage. With other items though it’s more a case of service when you detect a deterioration or there’s an issue. With CD players there’s the added risk of mech failure during shipping to take into account. With these items I don’t think Naim are saying not to service them, just that there’s no set regime or rigid time limit like there is with the power amps and power supplies.
