Music stream from a server via Foobar2k. If Foobar2k remains open while a radio station is selected with the tablet, the radio station is running, ok. But if Foobar then closed, the radio stream is interrupted and the NaimApp radio button remains active.
I have no experience of Foobar, so I can’t answer your specific question. However, Naim streamers are designed primarily to work with UPnP servers. I think I am right in saying that Foobar is not a fully fledged UPnP server (although there is a plugin that supports it). If you use it for serving locally stored music files, I wonder if something like Asset would be better behaved.
The QNAP music server switches the NAS to upnp and interrupts the radio stream, I suppose and Asset wont do that?
I had already installed Asset in the course of other backgrounds and it seemed to me to be quite antiquated in its operation. But as it looks, I will have to deal with it in more detail.
