Hi Can I pair an NDS2 with a DR’d 555ps also do I connect with two Burndy cables and which type?
Yes, the NDS was made to work with a 555 and makes the most from the power supply, it’s a super combination. I had an XPS DR first with my NDS and then upgraded to a 555DR. The upgrade isn’t a subtle one and is very worthwhile.
You need the twin Burndy set, the current listing is called Burndy Set for NAPS555, 00-010-0108.
My NDS was revolutionised when I stuck a PS555DR on it.
Do it!
