I have been combing the forum to get a how to guide connecting my SonicTransporter to the NDS. I am not sure how it is supposed to connect and thought it was a plug and play solution using the SonoreUPnP Bridge app in the sonicTransporter. Am I correct in assuming this high level theory? The NDS connects to the sonicTransporter via UPnp and I can then use Roon on the sonicTransporter to play the streaming services and the NDS outputs it via RCA cables to my Platin Hub that wirelessly sends the signal to the Buchardt A10 active speakers.
I am trying to get the best sound quality and thought that maybe NDS to the hub would be best vs a Lumin T2 connected via XLR to the A10s directly or even using the sonicTransporter via Roon to the Plain hub.
Figuring this all out so that I can sell the systems that I don’t use. IMHO out of the box NDS → RCA → to Platin Hub → wireless to the A10. I use the Naim app but it’s not as pretty and nice as Roon and as well it doesn’t support Qobuz which I might just get rid of and stick with Tidal.
Answers are appreciated so that I can figure this all out.
Have you tried Audirivana? connects to nds with upnp over wifi, plays hires, you just need a computer somewhere to run it. can control it using an iphone etc. sounds wicked, no gadgets needed
Hi again. I couldn’t get it to work after another attempt. I tried Audirivana and it worked straight out of the box in 2 minutes. You are right where it sounds great. Now what to do is the question. Thanks for your recommendation.
This is my plan having played around with Audirivana for around 6 months, get a mac mini and that fancy new ipad pro. continue enjoying my NDS with x2 555ps
Did you use Roon before? I have Roon and I switch between two systems. One at home and one at my office. I just don’t want to pay for two services. What is it that you like about Audirvana?
That’s the settings that should get you running, will leave what happens to the output from the NDS to your configuration.
Enjoying my NDS with two PSUs, one being a 555DR on digital, with Roon for nearly 10 years now. Roon from 2015, NDS from 2016
(ND5XS/NP5XS in 2013 → NDS/NP5XS → NDS/555DR → NDS with dual power supplies) into Sim Audio Moon i5 integrated & B&W 805 Signatures.
So you want to take your digital signal through an NDS converting to analogue, then convert it back to digital to send to the speakers, where their DACs convert back to analogue? Maybe it would sound better excluding the NDS, though that would negate use of the Naim app. Seems worth at least trying with it excluded and compare.
