Is it possible to use a Naim NDX with Apple Music? I haven’t found a way to do it.
Assuming that you mean the original, not the NDX2, there are a couple of options. One is to use a wired connection to the front USB port and play from an iOS device. The other is to get an Airport Express, connect it to the streamer with an optical cable, and use Airplay to connect to that.
Thanks ChrisSU. Yes it is an original NDX. I think that using my Macbook pro would probably be the easiest method and being wired, probably more reliable.
