It is/was weird. Changing radio stations didn’t work and caused the device to (temporarily) go ofline in the app.
My iRadio has been back on for the last hour or so and seems to be working OK but the multi room function seems to have disappeared, anyone else having the same problem?
Exactly what happened this morning on my qb first generation. Qb visible but could not be started. Then the warning about another app already connected, but no way I know the limitations and never use other than my main iphone to command this qb.
Power down and up no sound.
This evening I used the usb connection and my radio apps to play over the qb and this works fine. This falling off the naim app happens from time to time but is usually resolved by playing directly from the iphone over usb lightning to usb that is, not today it seems. Nice to know others have the same problem.
Claus
