NDX: cannot be found by the app. Through the remote control I am able to connect it to uPnP en listen to the music. But no Tidal, no Iradio.
Mu-So: can b found on the App but no Iradio e.g.
Internet is working since I am workin on a computer.
Any suggestions what the problem is here? I live in the Netherlands.
I don’t know if it’s the same issue but my Mu-so1 and Qb1 both died today. They wouldn’t play anything, then said another client was connected. They kept disappearing off the app so I did a factory reset. That worked but they still won’t connect if I try to play anything. They just hang while connecting and then disappear
Naim last updated the app about a month ago. There hasn’t been a 1st gen. streamer update for ages, and if you had done it, you would know because it’s a manual update. I think you need to look elsewhere.
