NDX Ground Setting with Weiss DAC501 MK2
Hi Folks,
I am using NDX/XPS-DR/282/HC-DR/250.2 for current system and I had added the second source (Weiss DAC501 MK2) to the system.
Could kindly advise what is the ground setting on NDX should I select ? Chassic or Floating ?
Thanks for advise and support !!!
there may be a subtle difference in sound in either position, but ive found no difference but it depends on how the weiss is earthed, just try in both positions and see if you hear any change.
It will depend upon whether the Weiss has its signal ground connected to earth or not. Probably best to ask them. If so, set the NDX to floating, if not, set it to chassis.
@Richard.Dane @Hifi-dog
Thanks for your advise, let me consult Weiss for the question :smiley:
