NDX with external DAC,
Hi,
I am using the NDX with XPS-DR and have interest to add the external DAC.
I would like to know do I need the XPS-DR on NDX when use the external DAC ?
marcobb0312s
You can use the XPS on either. Probably best sound quality will be with it on the NDAC.
No.
But the xpsdr on the Ndac will uplift nicely the sound.
Sorry to miss information, I will not use the NDAC, I am considering other non naim DAC.
If you are using a non-Naim DAC then you may as well sell the XPS. The link plug is much cheaper :slightly_smiling_face:
Noted and Thanks !!!
I suspect that you will hear a subtle improvement with the XPS but I can’t imagine that it would be anywhere near enough to justify keeping it. It would be interesting to hear if you can tell the difference if you have a chance to compare.
