NDX2 + external tube DAC
Wondering whether anyone has any experience adding an external tube DAC to the NDX2.
LAMPIZATOR? Maybe?
Yes, am curious about the Baltic line (the main ones waaaaay outside my budget). But I’m wondering whether anyone else has any experience with external tube DACs for the NDX2.
There is one here with the lampizator. Tap it on the search page here and ask him, using @his avatar.
yep - I created a valve output stage on my DAVE DAC fed by my NDX2 . I used a Little Dot Mk III with home rolled valves on the analogue output stag of the DAVE .. it was good .. Id say it was like adding a thin lace veil to the sound.. it was attractive with headphones - but with speakers and transistorised power amp (N50), I preferred it solid state all the way as it tended to be more immersive and dimensional… but that could be with my setup.. but with headphones I though it was great - if not really super tight and transparent like higher end transistorised amplification ( or possibly less coloured)
You do appear to get a slight compression effect with valves (depending on circuitry) which can be attractive with a high resolution DAC.
The good thing if you are willing to experiment you can try these things out with out it costing a huge amount., before you go down very niche paths.
The little Dot Mk III has both headphone and line out from the valve amp stage.
Hi, very, very much thanks for this. But I have headphones issues (don’t have them and can’t get myself to want them!)
But I want to hear if there are any whoever run it from streamer to amp to amplifier!
Thanks to all and have any relevant experience and can share.
Lisa
Yes that I was doing and describing… the little dot is a valve preamp with a line output for an amp as well as a headphone output if you want to use those as well.
So I was using as a valve preamp from my DAC reconstruction stage.. the line out is less coloured by the valves compared to the headphone output.
Quoted from the a web site
Valve/Tube Stage: The pre-amp output is actively driven by both the driver and power valves (e.g., 6J1 and 6N6 on the MK II, or GE5654 and 6H6PI on the MK III), giving your downstream gear (like powered studio monitors or a power amplifier) a touch of valve warmth and high voltage swing (typically around 10V RMS
I use ndx2 and lampizator atlantic trp3 and I am very satisfied. Previously I had a 555ps with the help of which the ndx2 works much better, but the tubes dac gives a completely different perception of the sound in my opinion. The sound becomes more organic, silky, spreading around the room in all directions, much better. @N-L can also share his experience. I didn’t listen to the Nd555+555ps in my room, but I would like to compare it with the lampizer (which can play magically by changing the factory lamps).
Thanks for responding. I’m not certain the LampizatOr is in my budget. I recently changed a tube in my pre-amp (I have a Naim system and a tube system side by side) that has lifted the tube system (through which I also use the NDX2) over the Naim by a considerable margin - and I don’t just mean adding warmth and integration. Having had the NDX2 for a good number of years now, I was wondering what might be the result if I streamed through an external (tube) DAC.
