Hi all, hope you can help, I’ve just received my new NDX2 and all set up fine, I have used standard RCA to output to my non Naim amp but I can’t get any sound? The amp is fine on other inputs and I’ve tried this on a couple of different inputs??
Have you set the output to RCA - it is set to DIN by default.
Ah no didn’t see where to do that?
Press Disp on the Remote.
O - DIN (default)
oo - Phono
O oo - Both
For best results, do not select Both…
Perfect thanks all good now👍
Brilliant thank you
Easy. When you…know…
The Zigbee remote that comes with the NDX2 doesn’t have a ‘disp’ button, and the only way to select the output is using the Focal/Naim App.
Thats what i thought. But, it would be a whole lot easier if naim had stuck a hard wired switch on the back like the cd5xs.
