I have a very new NDX2 which has worked flawlessly with Tidal up to now
Today I have been swapping mains cables and reassembled
Unfortunately I can no longer get Tidal to play through my NDX2 using the Tidal App even though the NDX2 is visible on the App
It does however still work using the Naim App.
HAs anyone got any suggestions to fix this please ?
Steve
Try logging out of Tidal via the app itself.
Log back in.
Just reinstalled Tidal to also no change
Steve
Ok, what is the tidal app displaying?
It shows the NDX as available ‘Tidal Connect’ in faint text below its name
When I select it the tidal stream as
started via the Naim App stops and no sound output is heard
When looking back to the selection screen the NDX2 has the tick next to it but silent ?
Steve
Claus
July 20, 2024, 5:51pm
6
Sounds a bit like something I have run into a few times. Try playing something from the tidal app using airplay and then try connect again. Sounds totally strange but it has worked for me. If it does not sign out of tidal on both tidal app and naim app and sign in again.
The OP had tried this, see above.
Wow that Worked just Airplay then back again !!!
Thanks a million both of you for your guidance
Steve
Claus
July 20, 2024, 7:22pm
9
No had tried to reinstall the Tidal app. Anyway problem solved. I just hope that naim support is aware of this strange solution.
Claus
