I was wondering how to control the volume of my music with the NDX2 remote (after all, it’s got the buttons so I assume they can be used in some way or other). When I go into the app; ‘Settings’, then ‘Volume mode’ ticking ‘Hybrid’ or ‘Fixed’ allows the music to play but no volume control via remote is possible, but ticking ‘Variable’ just stops the sound completely. Am I misunderstanding something significant, and is it possible to control the volume via the remote at all ?
Once you have the two boxes wired as lamby explains above, you should enable system automation in the app. You’ll then be able to control the volume and inputs via remote or app.
Note that enabling system automation disables the NDX variable output. Ensure that you set the system automation preamp input to the input that the NDX2 is connected to.
Ha ha no problem- that’s the point of this forum. Although you do have to take some comments with a huge pinch of salt and try things for yourself. But for tech issues it’s great.
