What are your findings on different stands for the XLS compared to the original ones?
Especially any experiences with Skylan stands?
These are my stands but can’t remember the brand/maker
I’ll find out from my dealer today and let you know
Very solid and certainly do the trick
Hi Dodo
My stands are the Momentum stands that Neat use to recommend to use with XLS’s although they did have a special neat stand which was horrendously expensive so got dropped
Neat are now recommending the dedicated specially made stand for the XLS’s by Custom Design UK so have a look at their website
I should add my stands are excellent
Trust this is of some help
Thanks Bevo, the picture is very nice!
No one here who had tried Skylan stands?
