NEET-1008 Neotech Ethernet RJ45 Cable
Another Lovely Post i totally agree with. Will copy it to the sigma thread :blush:
A cable which needs 1000h burn in. That is Not Maximum User friendly. And after 150h the Curve flattens i think
Trust our ears as well and try the sigma.
Maybe you will have a Life changing moment
I do. I trust your ears regarding the Sigma and will listen to it. The Neet I don’t know😅
What’s it like for instrumental texture of classical and jazz? I find some quiet and smooth filtered cables kill that completely. Is the Sigma different? (assumion that is your kind of music…)
@Michaelb I am no classical or jazz listener.
But instruments of any kind are rendered in really special way - much detailed without any edges. Fast and layered - really good texture. There is nothing smooth - especially it will not be in your system.
Analog what it desired best!
With your really advanced system you should definitely give it a try!
@Michaelb
I collected the impressions on sigma in a separate thread
It is absolutely perfect for jazz - playing some right now. And had a nice classical evening the other night. As Drago said it really is a pretty neutral and characterless cable that can deal with just about everything! In fact I can’t think of anything I’ve fed it that’s been disappointing, which is something I find quite refreshing. With other cables you get to know what they favour or embellish and often jump through album tracks to find them. With Sigma I’m playing the first track and I get sucked into the whole album. Even albums I don’t particularly like have taken on a new life. I don’t think either of us can do justice describing the sound, you really have to hear it for yourself. There is something quite special about it.
Oh…love your speakers. Heard some a couple of weeks ago. If i didn’t have DBL’s they would be my go-to. Awesome!
With all cables tested before feet are moving with music.
With sigma feet and head are moving!
A bit all over the place tonight, as in not that great.
Switch back over to streaming, much better.
Midrange has disappeared tonight right now, and sounds horrible, hopefully it won’t last long and i will be putting it on a big play list later tonight.
Sorry, I if I am being a bit slow. Is this the copper or silver version of the Neotech you are talking about in this thread?
Silver
Well it’s still a bit harsh and horrible.
I think i am going to have to remove it and burn it on something else for a month as i can’t take anymore.
Hopefully after this it will have come good or at least better.
But right now i can’t recommend this cable at all, but i was kinda expecting it
If it’s that bad in your system something is not right. Maybe it doesn’t work at all in your setup. Which Ethernet cable did it replace?
The standard cable that came with the PhoenixNet
There was no standard cable in the PN I tried. Are you sure it is one included? What cable is it?
Well i got one with mine.
But mine wasn’t new out the box, so i guess i might have got a bonus thrown in by the dealer by mistake? But just thought it was a innuos cable that came with it.
I got one with mine too, it was a brand new sealed unit.
Come to think of it. I actually found the system sounding horrible at times during burn in. I might still do. We will see once I get home. :sweat_smile:
From new there is a short cable included - a black one :blush:
:smile: I think you need Sigma? Maybe maybe Neo Ethernet is the faulty link. Don’t be to convinced :sunglasses:
