A question for the network experts on the Forum.
Presently I use a Netgear GS105 Network Switch and a pair of TP-Link MC100CM Fibre Media converters, which is inside the cabinet that the Linn Selekt DSM sits on.
This is connected to the first Network Switch, Netgear GS105 near the Fibre Mesh Router, unfortunately, this has only one spare RJ45 socket. All the Ethernet cables are CatSnake 6a Floating. And the Fibre Patch Lead is OM1.
Reading some comments on the Forum about using Cisco switches and looking at some used ones on eBay, but need a bit of guidance with what I’m thinking of doing.
Considering a Cisco Netwotk Switch, (either 2960 or 3560), with an IEC plug, so that it has an earth / ground plus a SFP socket. This would go near the Fibre Mesh Router in the Halkway, replacing the first Netgear GS105. This in turn would feed the upstairs and downstairs switches.
Are these difficult to set up or are they “Plug and Play"?
This would give me the following options;
- Keep the Netgear GS105 to feed the TV only, keeping the iFI Power2 SMPS. Feed one TP-Link MC100CM with a Fibre Patch Lead from the Cisco via a SFP Plug.
- Remove the Netgear GS105 and iFI SMPS, use an inline Ethernet coupler. Feed one TP-Link MC100CM with a Fibre Patch Lead from the Cisco.
Option 1, would have less connections in the cable run, plus one less MC100CM, one less iFI SMPSs in the near vicinity of the Linn DMS. A longer Fibre Lead run.
Option 2, would have less connections in the cable run, plus one less Netgear GS105 and one less MC100CM, two less iFI SMPSs in the near vicinity of the Linn DMS. A longer Fibre Patch Lead run.
Regarding the SFP Module 1000Base, would this be suitable for the Cisco Network Switch, as the MC100CM is 100Base or does it require a SFP Module 100Base? Having a problem finding a 100Base version, also some are shown as SFP or SFP+, are they compatible?
Regarding the Fibre Patch Lead looking at this OM1 version.
One question is, how flexible and resilient are they, would it be OK in my trunking?
The top channel is power, the middle channel is loudspeaker cable and the bottom channel is data cables.
Apologies for all the questions and any incorrect terminology, please feel free to correct, as advised earlier, this is new to me but very interesting.
DG…
