Maybe this will be the answer to all those dodgy vinyl discs.
Seems that T Bone Burnet is working on a format that combines the benefits of vinyl and CD. Ionic Original claims to offer master disc quality using an alloy based disc similar to an LP that’s spun and read with a stylus.
I’ve seen nothing so far that indicates whether existing TTs will read this format, but Bob Dylan has recorded songs on the format.
Maybe another bright idea like Betamax that will go nowhere. We shall see.
A new version of the acetate disk on an aluminium platter?
Now if Phillips or Sony were behind it… There was a revival of Edison cylinders with field recordings a few years ago for folk musicians to sing or play along with. Bound to be a curiosity, nothing more.
In 1985, GZ implemented the DMM (Direct Metal Mastering) technology founded by the German company Teldec. This technology involves the production of steel plates which are coated by a layer of copper through a special galvanic process. The advantage of manufacturing our own copper plates is the possibility to control their quality and adapt the number of plates produced according to the pressing requirements. After cutting the audio grooves into the copper layer (see page Mastering) and engraving them with information necessary for identification, the plates are then immersed as a cathode in an electroforming bath. An electric current flowing throughout the bath from the nickel anode to the cathode creates a deposit of nickel atoms onto the copper layer. We then get a mirrored image (negative) of the plate after separating the accrued nickel layer, therefore yielding an unformed stamper. DMM technology allows for several sonically accurate stampers to be directly produced from 1 DMM plate.
