I have a USB stick plugged into my NDX2. I have approximately 650 albums on the USB stick.
The app now shows over 2000 albums. The reason is that the albums are duplicated several times!
I pulled out the USB stick and rebooted the NDX2. I still get multiple copies of the same albums on the USB stick!
I wonder whether the server mode is doing something strange. Itās very odd that two people have found this, on an Atom and now a NDX2. Maybe Naim can suggest the cause? @Stevesky
It is a very similar problem indeed. The thing is, I have had the same USB stick plugged into the NDX2 for a few years now. Nothing has changed, but now it shows duplicate albums for some reason. Before yesterday, it was fine. This is a real head scratcher.
Mine seems to be behaving again now thanks to the huge amount of help Iāve had from forum members.
I was getting usually 2 copies of about 100 albums out of ~500 albums. Some had 5 duplicates.
I keep all the flac files on my PC, so I reformatted the 1TB SSD I use and recopied all the files to it.
I plugged the SSD back in then Cleared the Image cache and Rebuilt the database
That seems to have sorted it out.
Iām going to repeat the process this evening as Iāve ripped about 50 more and see how it looks on the app.
Daniel, would certainly follow Petesā suggestions above. Out of interest, are you copying music from a PC or MAC? Also what happens when you try to play those duplicates - do the duplicate names play the same duplicate track?
I ripped my CDs on a MAC, and transferred the files to the USB stick. All is well when I play any of the duplicate albums. The only problem is the duplicates themselves.
I cleared the image cache but still have the problem. Curiously, only albums with an artist name starting with āAā seem to have duplicates, but not all starting with āAā have duplicates.
Some albums appear as much as 82 times each!
As you are using a Mac, have you tried emptying the Trash Bin when the USB drive is inserted, as any deletions will be placed into a folder on that drive called ā.Trashā, and I donāt know if the Naim App is clever enough to ignore it (one would hope so, but worth an extra check)
If you are using a Mac then the usb stick will contain a set of hidden MAC OS specific files which it uses for indexing and searching and will be confusing this indexingā¦
I use a utility called OptimUSB to strip this out (and empty the trash at the same time). It costs a few pounds
You can write a shell script to do the same thing or find one on the internet
It still seems to be available in the App Store and works on my M1 iMac with the latest OS (and every previous one for the last 6 years)
Thanks, but as you indicated, I do use my own shell script that uses rsync and then strips out spotlight indexes etc.
Worth a try. Just to confirm, and sorry if this is obvious, but you do need to insert the USB drive to see if the USB drive bin is empty. Without the USB drive being inserted, the bin being empty just relates to the Disk Drive in your Mac
I donāt remember what system it is formatted in.
The thing to remember, is that the USB stick has been in use for years without any problems. The duplicate albums just appeared a few days ago. I am wondering if the USB stick is corrupted in some way?
I finally solved the problem. I took out the USB stick then went to settings in the app and I chose āRebuild music databaseā.
I then switched off the NDX2, turned it back on and inserted the USB stick. All is well now!
