I have a new Qobuz account. I wonder how I can change my Qobuz account in the Naim app.
I’d guess just sign in to Qobuz on the Naim app with the new password.
That’s what I thought as well … But on the Naim app I can’t sign in to Qobuz.
Try deleting the Naim app, then reload it and click on the Qobuz icon in sources on the Naim app. You’ll have to sign in then. I had to dump the app just yesterday and had to sign in to Qobuz in order for the "presets-albums-tracks-artists… heading to appear.
OK, will try that. Thanks!
Why not, you must have done it before you changed to a new account. Surely you can just sign out of Qobuz on the Naim app then sign back in with your new details?
That would make much sense but somehow I can’t sign out …
I did find that changing a password it seemed to need 24 hours to be reset, before i could start using and logging in?
This looks like the screen I’ve missed so far … Not sure if it appears in my app. Have to check it when I’m back home.
Go to input settings, pick Qobuz and it’s there.
Found it, thanks!
