Hi All,
I recently posted about moving a SN2 into my system. It’s displacing a much loved XS2 and I guess like most people that that come here, I can’t resist sharing my observations, and seeking some advice.
It was run in by the last owner so I could get right to listening and, like many others have posted, the difference in sound quality was immediately apparent. I’m not quite sure how to express it; more grip, more depth, more grunt…just more. I’ve been going back and forth between my Rega Planar 6/Ania Pro/StageLine and ND5 XS2/nDAC and overall I’m very pleased.
One item that I’ve been trying to process is how the gap between my TT and streamer has grown. With the XS2 I felt like my Planar 6 and ND5 XS2 were closer in SQ. Both my wife and I have always leaned towards the TT but agreed the streamer was very good and would often default to it out of convenience. With the SN2 the Planar 6 is the clear winner.
Another change that Iv’e noticed is that since adding the SN2 the system is the it’s a bit more “fatiguing”. I’ve been adapting to it, and it’s not enough to make it an overall negative experience, but it’s noticeable.
I’m curious what you might think about my comments above and also what you might recommend for next steps. I’m a bit of an opportunist given I try to buy from the used market but I’m contemplating the following:
Replace my Focal Chorus 726’s. This has been on the list for a long time but have been focusing on other aspects. Neat Majistra’s, Spender A4’s and PMC Twenty5.23i’s are some that I’m considering.
Replace my Naim StageLine S with a Rega Aria.
Add a HiCap DR to the SN2.
Other?
Thank you in advance for any thoughts you may have.
