I bet that sounds great! I just can’t believe a casing would double the cost to the Klimax. Did you ever run the Selekt into an amp or have you always had it connected to the Akubariks?
Big difference there.
I did the change so let my wallet speak for me it’s quite a fundamental upgrade easily demonstrated at a good dealer.
Not cheap but upgraded definitely.
That example is a comparison of early Radikal my own one is a Black Klimax Radikal 2.
My Akubariks are passive so the Selekt runs into Solos, Solos to Akubariks.
I’m pretty sure that the Selekt casing is way more crowded, a d in any case the guage of the case metal is MUCH thiner than illustrated.
That was just to show the different casing structure on Radikal
It shouldn’t make any difference how crowded the boxes are really as from folded steel to milled billet is far superior.
Agree about the Klimax case, but not about how crowded a bom might be.
Everything is relative being like for like.
Same in each will have the same effect.
Agreed…I misinterpreted your meaning.
No problem at all.
