No radio since 2hours
Cannot reach any radio since 2 hours. Any issue or is it my Nd5xs2 itself ? Tidal working perfectly.
I’m listening to BBC radio on my Nova as I type (UK based).
Location would help
\martin
No issue here in The Netherlands
Hello. France.
Good to know, looking into this
Martin
Hi @Jubeph
I just chatted with our IT teams and they seem to have some dns issues in France. This is definitely annoying station logo and artwork delivery from Cloudflare, but can affect access to the directory as well.
i’ll keep an eye on it as can see the problem when using a VPN so will post once they have fixed things.
Beet
Steve
Hello again,
The problem should be solved. As the DNS has had issues, and bad info may be in caches turn the power off on your streamer, wait 20 secs, power it back up and then hopefully all should be good again.
Steve
Hello Steve.
It seems working normally now. Thanks for help and replies.
Phil from France
Dear
Again it’s very long to change radio and even on Tidal each song take a very long time to start.
Tried different solution but always the same.
Phil
