No sound after reassembling system
Stripped down system to clean Fraim and connect and reconnect cables. After reassembly no sound, all lights on and source is working as can see Roon indicates playing and will play to iPad. Pretty sure everything reconnected as before, but could be wrong. Any suggestions for narrowing down the problem would be welcome.
Antipodes k50 server/streamer
Naim Dac (original one)
XPS DR
Supernait 2
HicapDR
Obviously check any mute button.
Then double check all connections. Particularly in and out of the DAC.
Thanks for that, problem solved , had accidentally flicked dac output switch from din to rca.
Very relieved esp given lack of service in NZ.
