Hello I’m trying to connect my front speakers to my supernait via my avr’s pre outs. But no sound is coming out. I don’t have the supernait remote control and I’m wondering if this is possible to do it without one. If not what remote works?
Also I want to use a valve amp as the pre and have a nd5 ns. I’ve heard it doesn’t do much apart from power the super air pre amp? Is it worth keeping? Thanks
Nd5xs? That’s a streamer.
Do you mean hicap? A hicap (or supercap) can be used to power the preamp stage of a supernait instead of the internal power supply. So if you use an external preamp, a hicap would be redundant.
