Great new band name there for someone.
The golden age of ârock musicâ was mid-sixties to mid-seventies, which by an amazing coincidence coincided with my (music likes/dislikes) formative teenage/early twenties yearsâŠâŠ
Since then, with a few exceptions, IMNSHO the overwhelming morass of âpopular musicâ has been utter dross!
As usual, other (misguided) opinions are available, and YMMV (even if itâs wrong).
You know, I feel so much better for thatâŠâŠâŠâŠ
I assumed it was the name of a Canadian DM tribute act.
I have considered going back and listening to some Queen albums careful to avoid the tracks I mentioned. However thereâs so much music I know I do like to listen to but I still might. Think their best track was Under Pressure Bowie helped ground the song imo.
Are they loose aboot the hoose?
Have you listened to Jazz Sabbath?
Yep, got both albums
Try to have a listen to Miles Davisâs LP âIn A Silent Wayâ. (If your system has good resolving capabilities, you may be able to hear the valve amps humming!)
Itâs unlike anything else that he recorded, and may be a gentle introduction to a small part of the massive morass that is jazz.
Iâll give it a goâŠ
Thatâs as maybe, but jazz influenced is not jazz!
A lot of rock, and other styles, have jazz influences, and crossover (e.g. âjazz rockâ), but to me there is a point where music bacomes too jazzy and I dislike it.
I saw Adam Wakeman last week, and he mentioned it and played one number (Iron man). Whilst it was OK in a live setting, amid other music, I had a listen to that and several other tracks from both albums on Spotify afterwards and found nothing to like, indeed it wasnât long before it started grating.
As somebody who listens to a bit of Jazz as soon as I play it I can hear the âJazzâ. Bill Wardâs solo albums are Jazz.
Iâm not too clear as to your point - are you saying that to you that track IS jazz, or just that it is jazz influenced? If the former, then by your assessment of jazz I do like some. If youâre simply saying it is jazz influenced, or has some jazz rhythms or whatever, then as I acknowledged that is not uncommon in lots of music and it doesnât make me like jazz - nor is it likely ever to as it hasnât in 50-odd years!
Itâs Billâs Jazz style drumming that give it a Jazz flavour thatâs all. You may not have recognised that if you donât listen to any Jazz but as I do I was able to spot it.
Well, jazz influences permeate into many things - sometimes it can be positive, depending on what the influence is and what the music is, but only up to a point. Once the jazziness exceeds a certain point it kills it for me. But it is impossible to define what that point is!
I find it much easier to say âI like thisâ and âI do not like thisâ.
If you really want to define yourself as a music snob thatâs the point isnât It? This is x. This is influenced by x.
I used to sit in work with a wonderful colleague who could tell me at length what was and wasnât punk. Always struck me that if punk was as open minded as it proclaimed then most punks didnât look or sound like punks snd yet for some they have to or theyâre not.
I could not give a fig about genre or influence. Can I connect with it? Do I enjoy it? Is it any good?
Bands/Performers I dislike intensely:
(1) Aerosmith
(2) The Beatles
(3) David Bowie
(4) Ted Nugent
(5) Beyoncé
(6) The Doors
(7) The Smiths
(8) Radiohead
(9) Dixie Chicks
(10) Elvis (except Blue Christmas)
(11) All Rap, Jazz (except Kind of Blue) and any old style country
is it possible that what you regard as jazz style drumming is not unique to jazz? Maybe common to other music styles?
Regardless, I bet they all sound fantastic on those K10âs!
Are you familiar with FWB? Did you have a particular style in mind?
