Well this is a bit odd….does anyone know why this album would be “not playable on Naim”? I can stream no problem on Tidal to other devices. I’ve never come across this issue with any other album.
Just FYI I use a Uniti Star
Probably they only have it in a MQA version. They supply CD quality to Naim streamers, so if there isn’t a CD quality version available then it is “Not playable on Naim”.
I believe you are trying to play the Dolby Atmos version, which will not play in a Uniti Star.
There should be another version, one line above or below, that is a FLAC file and will play beautifully.
It plays very well in my SuperUniti.
