Just upgraded from a Uniti-2 which was showing signs of its age to a Nova. I can’t help it but I feel disappointed with it. Don’t get me wrong it’s sounds good but not as good as the Uniti. One thing is that I feel as though I have gone a step backwards as I cannot get Apple Lossless any longer. With the Uniti I could connect via a cable, now with Airplay it’s just not as sharp. Also, with the Uniti I could change the input names, or disable them, but I can’t do this with the Nova. Am I missing something? Apart from my Uniti?
together with something like an Audioquest Dragonfly DAC to connect to an analog input, although I’m sure Nova’s DAC is far superior. Maybe you can run a USB cable between the Apple Camera Adaptor. and a Nova USB input.
Fellow Nova owner here. Give it some time to settle in. When I first got mine, I thought I had made a mistake as I wasn’t excited by the sound however, after a month, it started to settle in and sound awesome.
Hi there
I’ve been using my Nova for a few years now and whilst I can’t back-compare with Uniti-2 I’m very happy SQ-wise.
I would expect Airplay to be less sharp than a cable connection.
Maybe the lightening to usb camera adapter could work?
I am colonised by apple for almost all my tech but I use Tidal for streaming, it’s simpler to set up and pays the artists more. So +1 to what JamesBKK said.
You can’t use a Lightning to USB adapter. That would only work into a USB DAC, or possibly a USB to SPDIF converter if you really wanted to avoid Airplay.
Yes! More punch and control and better bass. Don’t ask me how but it works really well , see if you can borrow one or take a punt on used one… you won’t lose on it.
As per my example of the Audioquest Dragonfly. I’ve tried that and it works. I’ve never tried to connect the Camera Adapter directly to a USB port on the Nova, which is why I said maybe.
Yes, although it might seem a little odd to use an additional DAC, only for the Nova to digitise the signal and convert it again in its own DAC. Thus my suggestion that just a USB to SPDIF converter might be a neater solution. Either way, there are solutions out there.
