Greetings. I have a Nova. Love it - and have just purchased a set of Sennheiser headphones. But how do i set the Nova / app up so that i can use the headphones Without my usual room speakers
I use headphones with a Nova and as soon as you insert the headphone jack, the main speakers are automatically disabled. No need to do anything on the Naim app
Thats what i expected? However when i plug it in nothing happens …
So when you plug headphones in the music still comes from main speakers? Sounds like a faulty Nova and you need to talk to your dealer
Worth checking if for some reason the headphones max volume setting in the app is set at zero. It’s in the Audio Settings menu.
