Generaly if a unit is to be RMA’d it has to go back before you get the replacement - as a goodwill gesture I’d hope that could either be dispensed with by agreement with Naim or that the dealer could loan you a demo model in the interim - supply issues may make this tricky but you’ve forked out $4-5k for a Nova and shouldn’t be without a working one for long.
Small update…both times it failed, it was around 3 days apart.
Last time was last Tuesday.
I then unplugged again, left it overnight…and when replacing the power cord on the Wednesday, it made a loud click as it went into place.
I don’t recall it doing that before, and when I read the Powerline thread, it was very clear that you needed the click to be fully connected.
Given that it’s now 5 days since the last screen fail…I’m hoping that I could be in the clear? Could that really have simply been the lead not fully in?
Bit of a quandary now, as it’s working OK…but I don’t want a nasty surprise down the line if I call off the replacement.
Spoke too soon…its back tonight!
Back to plan A…
Drat, needs replacing I think.
Definitely,
It’s becoming more frequent now - whereas it would be okay for a few days, it’s now doing it every other day, sometimes more.
Going to speak to the dealer tomorrow - left it with them last Wednesday, and will have given them a couple of days after the Christmas opening up to (hopefully) have made a little progress…
Update from the dealer today.
Problem has been registered, and an replacement unit is being organised. I was told that for new stock , it’s pretty much a 6-8 week wait - but replacements are prioritised, and so will (hopefully) be with them in a couple of weeks. Can’t fault that!
What I didn’t know, is that the making of the screens is outsourced?
Even Apple outsource their screen manufacture (well everyone does actually).
Ah right! I had no idea. I’m not fussed, as long as the outsouce a working one!
It would never be economical (probably not even viable) for Naim to attempt to make their own displays, and presumably they use a standard readilly available one which meets required specs or have someone manufacturing a bespoke display which would be more expensive.
Had notice from the dealer yesterday, my replacement Nova will be with me tomorrow.
Got everything crossed for this one…!
Quick update - all set up this evening.
Don’t want to tempt fate, as the last one was okay for a few days before the problem kicked in…!
One thing to add, I’m sure this one sounds a lot better than the last one - wider, fuller…all the set-up is exactly the same. I’m sure I’m not imagining this…it sounds what I was expecting when I upgraded from the Atom. Weird!
Same firmware?
Not sure…it did an update when I turned it on.
I thought I was imagining it at first…the more things I try, I’m convinced it is a lot better out of the box than the last one.
Previous one sounded very ‘boxy’, not very open. Although I knew it was being replaced, I still lived with it for almost a month…and even then, it was the same. Thought it may burn in, it never did.
