I have just bought a second-hand Nova. It worked fine for a week but now it stops streaming and freezes. I have to unplug it and then switch it back on. It works for a while and then the same thing happens again. It is not under warranty. Any ideas and if I want to send it to Naim how do I do that?
Contact your local Naim dealer for any servicing needs. Or indeed to troubleshoot your issue.
Try a factory reset and software update…
Are you streaming local files or from a streaming service? Could very well be your network/router or ISP and not the Nova itself
Thank you. The Nova is in my garden room which is some way from the router. I will try it in the house and double up with a reset (the firmware is up to date)
… streaming Qobuz. Will check with local files. The app is not “seeing” the Nova and the on off light and volume switch are flashing/pulsating on and off every 2 seconds or so
yes try it in the house and connect directly to the router with a network cable as a test to rule out wifi funnies, not sure what the pulsating is indicative of but perhaps someone else can chime in
