NSC222 and NAP250 -XLR wires
Hello New Classic 200 owners,
I am looking for recommandations on xlr cables that you tried and work well with the NSC222 and NAP250
Thank you
Telluriumq ultra black
I have Chord Co. Epic X aray on mine - definitely better to Naims freebies IMHO!
Chord Signature TA or better would be my recommendation (tried a couple and decided on these)
If you’re in the US, you could try AV Options Signal interconnect.
Hi @Jean
I asked a similar question some time ago. Link to the thread is below:
Might be some info in there for you.
Thank you all.
Hi. I also own a Naim 200 classic series trio with Proac D20R loudspeakers, a pair of modified Lintons 85 and 1 pair of Sonus Faber lumina 2 with 2 Rel T9’s subs.
I’m looking for XLR cables, which XLR cables do you have?
I wonder how your Mofi sourcepoint 10 sounds with your system.
Do you like that match?
Milton
