Morning everyone, I’m in a bit of a quandary with my system..currently consists of NSC222/NPX300.
So obviously I need some loudspeakers although headphones are my primary listening choice at present.
I’ve always really liked PMC speakers and the 23’s in particular and have had several pairs over the years.
I’m tempted by a ex demo pair of twenty5 23i’s in active configuration but then I’m wondering if a NAP250 with Prodigy’s or Prophesy’s passive would be a better bet?
Obvious I know, but go listen and let your ears decide. Everyone here will have a different view.
I tried active Twenty5 24i but much, much preferred a pair of nap 350s into a pass8ve pair of Twenty5 24i. But of course there us a huge price difference. Active is convenient, but for me it was about the sound.
I’m a huge fan of actives. For me they bring the music alive in a way passive setups never quite manage. However, my experience is mainly with ATC rather than PMC. So, obviously, go and audition but I would include active SCM20s or 40s from ATC’s range in your audition list.
ATC’s SCM20s will likely work better in a small room, but I reckon they’re even more revealing than the 40s which I find a tad more “relaxed”.
I’d have thought 222/300 more than adequate for either. Mind you I got my 40s before NC came out and initially tried them with my then 272/XPSDR and preferred an Auralic Vega G2. As always auditioning is key.
Key thing I found with ATCs (passive and active) is they need volume to perform. PMCs are much better and more consistent for late night listening. The 23i/24i/26i all have a hot treble though. The Prophecy series is much better balanced and for me, sounds closer to the natural tonality of instruments. I was impressed with ATCs at higher volume but they lose energy when turned down.
I have a pair of active twenty5.21i and they are excellent, tight, fast and very engaging. As to whether you’d prefer a 250 and a pair of Prophecy I’ve no idea and only a demo will resolve that. The advantage of the active 23s is that they’d be a lot cheaper, which may or may not be an issue here. The Prodigy pair are probably a bit too budget for consideration alongside the twenty5 or Prophesy ranges.
