Hi all,
does anyone know if the remote out of the naim nsc222 could be used on non-naim amplifiers which a standard 3.5mm wire?
jonathan
Hi all,
jonathan
System automation only forwards the RC codes used by Naim. RC5 IIRC.
There’s a reasonable chance other things will also use RC5 codes though.
