I have a fairly old NDX and have updated the software in the past.
I probably have the cable but no idea where it is.
The NDX needs (I think) an RS232 (?) input and I need to connect it to my Laptop (ideally) since I don’t want to have to get at the back of the desktop.
So I think I neeed RS232 to USB. Laptop is Windows 7.
I’m not sure if it can support 24/192 (I have never tried). It just has one aerial on the back and does not have BlueTooth. I can’t remember when I bought it but was probably over 10 years ago.
“Please note, you must have a 24/192 compatible unit in order to use the new internet radio service. This can be checked from within the app by navigating to Settings → About. If the number highlighted below is a 1 or a 2, your unit is not compatible.”
Thats what I’m asking … does it have the 24/192 streaming board. This is an internal PCB with the required hardware to process 24/192 and enable associated and other functions.
A NDX with the 232 socket is a very early version, very likely it’s not 24/192, unless the PCB has been changed.
If you check the apps Settings → About as posted above to find out, if it’s not 24/192, you are kinda stuck with what you have, and it’s pointless to update the firmware
Yes I understand that Naim do install the latest firmware when replacing a screen as the replacement display requires newer firmware to operate correctly.
Good news … NDX is back with new screen. AND it has the latest software.
Bad news … I can’t enter my WiFi password. (I can enter it but the NDX won’t connect) so I assume it’s too long (34 characters). I have sent an email to Naim. It used to work and still works with my ND5XS. (It’s actually a pass-phrase and I don’t want to change it because we have lots of tablets, PC’s etc using it. I tried 5 times to enter it and I have it written down).
If I have to, can I reinstall an older version of firmware?
It’s possible to install old firmware in an NDX if you have them but if you are hoping that it might solve your login problem I doubt it will, and you will lose some functionality too. The first thing I would try is a factory reset.
You probably need clear an old Wi-Fi password.
There are 3 ways to do this.
1: Clear and replace via the front panel screen.
Press the Home button on your Naim remote control.
Navigate to and select Settings.
Select Network Settings>Wireless Setup.
Selecting Wireless Setup instantly clears the current saved Wi-Fi network and password from the unit.
You can then search for your network
2: Overwrite using Naim App
Go to the main Rooms screen and tap the “+”(Add New Device) icon at the top left.
Follow the prompts to pair your streamer to your network
3: Full Factory Reset
But best of all, especially as NDX does not have a robust modern stnd wifi connectivity, connect via ethernet, no password required.
