I would like to replace the already brittle rubber feet on the HiCap, Nac62 and Nap140 with new ones. Which feet can I use that match the original ones in diameter and height? Which ones do you use?
I would call Naim or tom tom audio.
ClassA is no option for me. It is too expensive to send Naim devives from Austria to UK. I bought new rubber feet on Amazon
There’s a industrial supplier in Los Angels by the name of McMaster Carr. You can normally find any thing you might need.
