I have the following equipment and for domestic reasons, need to pop it all into a dresser unit which has 3 good cupboards accessed by solid wood doors.
I’m planning to pop the Naim equipment inside, with the turntable on the top for easy access. Any thoughts on placement & order of placement?
Cupboard-1:
NAP 250 (chrome bumper)
XPS DR (to power CD-X2)
HiCap (Olive( to power NAC-82
Just for reference, in our bedroom dresser with 5 drawers.
Top draw. Pants
Second draw. Socks
Third draw. Her pants
Fourth draw. Her socks.
Fifth draw. Bits and bobs.
Hope that helps.
That’s not a dresser, it’s a chest of drawers. Our dresser has a cupboard at each end and three drawers in the centre. Glasses in the left, crockery in the right. Cutlery in the top drawer. Table cloths in the next and bits and bobs at the bottom.
Thanks for the comments - very amusing! Attached are pics of the dresser into which I plan to pop the Naim gear - any suggestions as to order & placement?
For domestic reasons nearly all of my full size Naim boxes are mostly housed in a record/equipment which has been canabilised. And some!
The things to watch out for are cable dresssing and ventilation. Naim kit is designed to work in extreme conditions, i.e. hot and that should not be a problem. Avoid sharp bends in cables, try to keep anything touching any ajacent walls.
Wether it sounds as good or nearly so as a sorted Fraim support I can’t say. It can be difficult to get the kit safely into the cupboard/s and neatly dressed. A 500 power amp is no light unit to fit without damage and care. Good luck with the project.
You shouldn’t stack the units directly on top of each other, so you really need to add two shelves to each section. You also need to remove the back for ventilation and keep it a decent distance from the wall. Then put the powered boxes on the right and the others on the left. Ideally of course you’d ditch the cupboard and get proper racks but presumably that’s a non starter.
I removed a sizeable section to give ventilation and to make cabling up feasible. I’m quite pleased with the result. I made shelves from 19mm MDF with a walnut veneer that are supported on mdf supports on either side. I sprayed these a dark brown.
Nee to pop some iron-on veneer on the shelves, but other than that, it’s aesthetically pleasing to me. I’m really satisfied with the sound too. Nice and tight.
Anil, congratulations it look fine and if it keeps domestic tranquility then it is time and money well spent! Look forward to hearing how you get on over the next several weeks with the new arrangement!
Nicely done, a credit to you! So much nicer looking (to me, of course), than any hi-fi racking. My smaller system lives on built-in alcove shelving, and also sounds great.
