Hi,
I have a simple question. Is this an original Naim RCA-5-din cable?
It looks like a Chord RCA - DIN. You can tell the earlier ones because they used nickel Deltron RCAs. As you probably know, Chord was started by Paul Stephenson’s wife at the time, Sally, with an aim to make cables for connecting Naim kit with other brands that used RCA phonos, and for a while the two companies worked closely both literally and figuratively. Even until fairly recently Naim’s own RCA - DIN cables were made for them by Chord (the Chord-specific RCA plugs were the give away, gold coloured for Naim).
Here’s a 4 x RCA Phono - DIN interconnect made by Chord for Naim Audio. It’s a later cable hence the nickel Deltrons are replaced by Chord’s own RCA Phonos;
Does this one have any directional marker at all? At some point the tails at the RCA end started to be printed with direction arrows but these can be easily worn off.
Thanx Richard. Do you think this is a good cable for connecting phono pre with RCA to Din Supernait1?
Yes, it should be a good choice, although those old nickel Deltrons can get a bit grungy and likely work best with nickel RCA sockets. Note that comparing the older and newer ones, I have a preference for the newer, whether that’s down to the connectors or the later grey cable, I don’t know. It’s no deal breaker though. Either is much better than the replacement (Crimson?), which I found rather disappointing in comparison.
Is a Chord Cobra the same quality?
It’s fine (and was more expensive IIRC) but in a Naim context I preferred the standard Chrysalis. Of course, it may suit your phono stage well, but you won’t know without trying it and comparing.
Dear Richard i have an other question regarding the “right” order for the mains connections in my Musicline netzleiste.
Set up:
Naim Supernait1
Naim CD5si
Naim ND5XS
Rega P2
Rega mini fono a2d
Which order, from the incoming lead connected to the wall socket, is best?
the order now is
SN1 first
Rega mini fono
Rega P2
CD5si
ND5xs
Probably a question best asked of Olaf at Focal Naim Deutschland who used to be with Musicline.
okay thanx!
The Chord Deltron RCA - DIN cable is great for Rega mini fono-Supernait 1. Clear and tight sound ![]()
