Phono cable recommendation
Hi all
Currently using technic sl1200mk7 with Rega aria phono, looking for a phono cable from turnable to phono, any recommendation?
Turnable to phono - ??
Photo to nac 252 - hiline
Nac252 to nap300 - SL cable
Nap300 to speaker - SL cable
I use Siltech Classic Legend 380i and Lyra PhonoPipe phono cables. Both sound better than anything else I tried (e.g. Cardas and Musical Surroundings).
I might upgrade my Siltech to the 680i spec.
Mine are DIN/XLR but all these are available in DIN/RCA versions as well.
I use my Linn supplied T Kable that turns out to be Mogami 2549 RCA
If it’s good enough and comes supplied with a five grand arm it’ll do me. :+1:
What cartridge do you have? If moving magnet, the cable between the deck and phono stage needs careful consideration for length and capacitance as it will affect the sound. Moving coil less so, but effective shielding to reduce interference is desired here.
