Reading through all the TT threads and a few others made me wonder whether anyone has ranked the phono stage options across the ranges? There was another thread where I think I saw someone say that the phono stage in the Nait 50 was ‘much better’ than the XS3 (?) Got me thinking about the relative performance in say the XS3, SN3, Nait50, and then the Stageline.
Anyone run through the options with a control group TT??
I would be sceptical of any direct comparisons between the Nait 50 and either of the other two.
The Nait 50 has a 100pF input impedance, the other two 470pF. Most modern MM/MI cartridges work better with a lower input impedance, giving the Nait 50 the edge. So I can easily see people preferring the Nait 50 in a direct comparison, but that of course doesn’t mean it’s inherently better, just that it works better with those carts.
To compare it fairly you’d have to use cables with high enough impedance to match that of the other two (and their cables). The XS3 and SN3 can of course be compared directly.
But of course we can say that the 50 will work with a much wider variety of cartridges, so for some that might be reason enough to go for that option.
Worth bearing in mind, the Stageline and Superline are not simply two phono stages, for example, a Stageline/FC, Stageline/HC, Stageline/SC are all effectively different stages.
The phono stages in the XS3 and SN3 are based on the Stageline circuit. No idea about the New Classic stuff.
For a while I ran my XS3 with a Stageline N, and compared between the two. There wasn’t a huge difference with my Goldring 1042 stylus/Roksan Corus body. I ended up running the Stageline most of the time but couldn’t categorically state I preferred it. In context in my system they were both “fine”
*I don’t mean to contradict you @IanRobertM! I doubt anyone has run through them all too, just wanted to write about the two I had compared
thanks guys - this is helpful. i wasn’t suggesting that there’s a 1-2-3-4 evaluation, more like what @gthack has said. if the XS3 and SN are based on the same Stageline circuit, stands to reason the phono stage itself would be comparable across the three. that point on why the 50 sounds different from @n-lot is also very enlightening for a non-electrical engineer like myself
I seem to remember that they were newer designs not simply copies, and only slightly different between each other as the pics above show.
Don’t know about the NSC222 phono stage which also still has the traditional 470 capacitance-load.
The Nait 50 has a completely new design phono altogether (now at a modern 100 capacitance-load).
Very good point, also valid when the pre-map is powered by these three and the Stageline hooked up via aux2. Also the SN3’s phono will improve with the HC-DR it’s often paired with.
Assuming you’re going for an MM or MI cart, personally I would go for Rega’s. But that’s purely on the basis of what I wrote above, that the Naim ones you list will severely limit your choice of cartridges. Or at least impedance will be way too high for most carts optimum. I haven’t actually listened to any of these.
But if you go for MC or find an MM/MI cart which likes high impedance (and are happy to stick with such a rare cart in the future), of course it would be different.
Worth bearing in mind that the loading on the Stageline, while seemingly much higher than just about any cartridge on the market, doesn’t really restrict you to a tiny number of esoteric cartridges with high capacitance.
Even with a selectable phono stage, you tend to start with the capacitance setting that matches as a baseline for your cartridge and then play with other loadings to see which actually sounds better. In a lot of cases, the preferred loading selector on a phono stage doesn’t exactly match the cartridge. The 470pF loading was more an aspect of it’s design when making synergy with the Linn MM carts of the time (which also weren’t 470pF).
So it is definitely true that it doesn’t have absolutely universal compatibility, but it’s not as strict is needing a high capacitance cartridge either. All the carts that are known to have natural synergy with the Stageline like the Linn, AudioTechnica, Dynavector, and Sumiko have 100pF loading. All the carts known to have compatibility issues and not be natural matches, like Ortofon, also have 100pF loading. And even that’s subjective.
The real trick with the Stageline is to let a dealer guide you to a natural partner cartridge brand. You can’t match with anything like some phono stages. But you can match it with a lot. Naim knew this which is why they still went for that loading as recently as the still very new (in Naim terms) XS3 and SN3 amps,
yes, definitely MM. I’m going to keep it as simple as I can - nothing fancier than a P6, ideally an in-built phono stage unless the Rega option is the clear choice. @feeling_zen 's point on cartridge matching might be the difference maker depending on what I see offered.
I sold my Pro-Ject III yesterday so will finally get the Rega TT I want. Was a mistake not getting the P3 in 2008, but you live and learn…
While of course you’re right that someone might prefer the sound with a “too high” loading, one important thing to note is that you’re effectively changing the frequency response. You’ll have early treble roll-off, and a peak in response just before that. Well into the audible range with a capacitance that high.
While generally you’d want a flat frequency response, or at least I would. And as the OP uses sources other than vinyl, one could safely assume he’d have the same preferred frequency response curve for every one of them, and not have a different one for vinyl. So he’d be better off with an equalizer
As I understand it that’s not entirely the case. High output MC’s will also be affected by the input capacitance, just less than MM / MI and more than LOMC. But I couldn’t say if 470pF would be an issue with the average cartridge or not.
Agreed. Ortofon’s popular 2M bronze/black (for example) specify a range of 100 - 300pF loading. The arm leads add about 100pF so another 470pF on top would be crazy and certainly sound wrong.
FWIW NA522 MM boards do not directly load the input with a parallel capacitor, instead (from memory) there is a 470ohm / 470pF low pass filter at the input. I’ve used these boards with a 2M Bronze and it worked brilliantly.
