I would love for this limitation to be removed. It serves no real purpose apart from cause problems for people like me that like to categorise their music into playlists.
My favourites playlist, which includes songs from all the other playlists has gone over 500.
I know I’m probably in the minority, but I don’t see why this limitation was put on in the frst place.
Hi, you’re not the first person to raise this issue. There is a workaround solution of sorts, but it only works for the old generation Naim streamers.
I would suggest that you send feedback to Naim directly, if they see that people want features, there’s a chance that they will add them if they can.
