First i would like to apologize for my English (i’m french), i haven’t write any message since a long time.
Since i upgraded my Uniti Star with the latest Firmware, i have issues with playlists larger than 200 tracks. When i play the playlist, the tracks are correctly added to the queue but when i try to select one track it switch to another and only the 20-30 first songs can be played. It even led the unit to become unresponsive a couple of times and i had to reboot.
Same issue whether the playlist is on the usb hard drive or Qobuz.
It only happens on playlists, no problems whatsoever with individual tracks or albums…
To bypass this problem i use the qobuz app on my android phone to cast it to the star and it works fine but i would like to know if someone had a similar problem and maybe a solution ?
Yes i Know, i’m far from the norm about this particular point but if unlocking this is not to much trouble for the software and/or device, i would definitely be happier with my Uniti Star
