Guys,
If this has come up before indulge me but sometimes the App randomly changes the running order of a playlist and even if I correct it it will go off and do its own thing.
Anyone else or suggestions?
Lindsay
Guys,
Lindsay
If you’re using an iPad or iPhone to control the App, beware the dreaded “Random Play” button on the bottom left hand side of the Play Queue screen.
Wouldn’t be the first time I’ve unknowingly touched it, with the resultant chaos.
Dave thanks but not that because if I edit the list and shut it down next I open it it will have done it’s own thing.
Does it appear on alphabetical order?
No normally tracks just appear in the order they were added to the list but then sometimes randomly reorder. If I then shift a track back to where I wanted it it will then again do it’s own thing!
