Silly question: where can I find Naim playlists, and how do I use them with Qobuz and Roon?
Not sure if this what you are looking for…
In Qobuz using the search feature you can type Naim Audio and hit enter and a couple of playlists appear:
NAIM AUDIO JUNE > Soundtrack special
NAIM AUDIO FEB > The Bristol Hi-Fi Show 2020
The qobuz and tidal playlist links are posted on campsite.
Brilliant - thanks
