Potential Innuos Issue
The last few days I’ve been having a strange issue….
I run an Innuos Zenith Mk 3 via an Ethernet cable into my ND555. Every track played (UPnP) has a short (approx 1 second) interruption around 10 seconds before the end.
Is anyone else having this issue ? I suppose I’m trying to narrow down whether it’s an Innuous or streamer issue.
I had a similar thing happened a year or two ago. Innuous tech support couldn’t find a fault but the issue disappeared at the next firmware update :thinking:. I emailed them on Monday but haven’t heard back as yet.
NB I’m using the Naim app rather than Innuous Sense.
Calling @Michaelb
If you’ve not done so already then powering down the ND555 and Zenith for a few mins and then re-starting them would be my first step.
No issue with mine here.
Mine is also fine. Are you streaming from local storage?
Mini first world crisis over. A good old fashioned reboot of both units appears to have sorted the issue as suggested above.
