The power outlet I need to use is on a breaker that says Loft/Back bedroom. I know this is not totally dedicated power but it seems to me it should be close to clean enough. It has nothing drawing power off it-like no tv-no washer/dryer-no lamps etc. Thoughts?cheers.
Hard to say. On the positive side, there will be no bad devices on the circuit to interfere. If it’s a radial circuit, then the earth wire will be effectively half the diameter, so not as good as a ring. If you had a dedicated circuit, then you would be using 6 or 10mm cable, so it wont be as good as that. Thing is to try and see
I will check on this-thanks.
What size fuse was it? 32A/16A?
