Me too! This is mine out in the open. I’ve currently got it sitting hidden behind some vinyl in my hifi unit. After making this I got addicted to expensive cables again and spent thousands on Ansuz. They are now gone and this is back in place. Does the job wonderfully.
Edit - this is actually the switched socket version I made for my home office desk setup. I’ve got an unswitched version in place for my hifi! Phew. Nearly committed sacrilege there!
This is turning into a “show us your power strip” so I’ll add one of mine.
metal clad MK, conduit fittings in the knockouts between the boxes hold it together. I added an earth post on this one to ground the amp when not using a Naim source.
I found the Matrix 2 only lasted a couple of years before the sockets became faulty. Taking it apart, I was surprised at how poorly assembled it is for the money. I bought a second hand Olson strip and upgraded the internal cable. It is doing a much better job.
I had the same with a Matrix-2. I tried to repair one for someone who used it with an AV setup. Parts and assy methods were very substandard and although I was able to repair it enough for use, he replaced it ASAP.
I recommend the Custom HiFi Cables / Sean Jacobs power blocks. They are well made, star earthed, good value and sound better than most costing many times the price.
I’ve made some good experiences with Audioquest NRG-X2 and NRG-Y2. Best price value has the NRG-X2. It’s also more flexible to use compared to the NRG-Y2. And you get a good variety of lengths.
However, I’m sure you have seen that others have also had a similar experience with the Matrix 2. Skeptikal has shown with his photo how poorly it is constructed. I would expect more for the money. I was very disappointed to see how it looked inside. I think my modified Olsen block makes things sound better than the Matrix 2, as well.
